Ergebnis 11 bis 15 von 15
13.02.2018, 13:34 #11
13.02.2018, 13:56 #12
AW: Vergleich Paris/Dakar Dekorsätze
Was die Haftfähigkeit nach Lagerung betrifft habe ich keine Info.
Die UV-Beständigkeit lag glaube ich bei 7 Jahren.
Müsste ich aber nochmal nachfragen.
Bei bedruckten Folien ohne Klarlacküberzug sieht das ganze nach vielen Jahren unansehnlich aus. Da geht schneller die Farbechtheit verloren als bei bereits farbigen Folien.
Ich habe noch ein paar Detailfoto`s oben eingefügt.Gruß aus Franken,
Ritschie
13.02.2018, 14:55 #13
Hab noch ein paar Bilder hinzugefügt......
Gruß aus Franken,
Ritschie
08.03.2018, 11:23 #14
- 06.12.2016
Hallo Ritschie,
I am Gian from Heritage Stickers and would like to thank you very much for running this test, it was very interesting and accurate!
It might be misread by me but it looks you haven't mentioned that in my set there are also: five spare red/white/grey pinstripes plus a long red stripe that goes across the tank, you can see them here:
http://www.heritagestickers.eu/cat/p...decals-1990-1/
Now, on to the problems.
You are right: the red on those decals of mine is not correct, not sure what happened but it's definitely not the usual red in stock otherwise I'd have received complains by now. Can you help me remember when you purchased that from me? Invoice number will do.
As for the lettering, what you call a font is not a ... font :) That has been totally redesigned from the genuine sticker to stay as close as possible to the original, I would like more photos of comparison with the OEM if possibile?
Speaking of the OEM, do you still have it with you? If so, maybe you could help me fix some details and move closer to perfection with mine? I would so much appreciate that help! Let me know if you can help with detailed photos, we can work this out together.
Once fixed, it'll be my pleasure to send you a correct R100GS Paris Dakar tank set for free.
Apologies for the English but unfortunately I can't speak German.
Look forward to hearing from you.
Thanks again for your test, I took it as an lucky chance to improve
Gian
08.03.2018, 18:35 #15
Abend Ritschie,
ein sehr objektiver Ergebnisbericht
Entlich mal wieder, was in diesem Forum, was Hand und Fuß hat und mit dem die Leser/Interessenten was anfangen können.
Ich gehöre nicht zu den Interessent für ein solchen Dekorsatz, aber dein Thread bietet trotzdem viele Infos die auch für andere Aufkleber gelten.
Viele Dank dafür...
Grüße Ingo
24.04.2024, 15:53 in Umbauten
