IMFSoft optical pickup up
tibbet
12. Sep. 2011
Lulea Schweden
Hi
Hope you excuse me writing in english.
Working on installing IMFSoft.com Universal Ignition with Hall alt. optical pickup.
Custom made Hall Pickup mount and indicator disk. Right pict new pickup mount.
Got a problem with the Hall pickup so I would like to use the optical pickup.
Anyone used this pickup would like know where the 3 wires should go into the connector. Couldn't find no marks on the connector socket or PC.
Guessed where the wires should go but before connect the unit I would like to be shure.
Mailed IMFSoft for advise but have to wait some days as it's eastern holliday.
Appreciate any tips.
Hello tibbet,
please have a look at the IMFSoft site.
http://imfsoft.com/en/hardware/universal-ignition#toc-specification
Here you can see all the sensor types with its wire color and the designation. Also the box connector with the related pin designation.
see Conection scheme of rotation engine sensors
and Connector scheme.
I think it is easy to understand the installation.
Best Regards
Hans-Jürgen
Got this great answer from Renate at IMFSoft
Hello Mr. Tiberg,
function of Universal ignition you can check by connecting inputs P and G – it must give a spark.
Kind regards
Renata Kolackova
Support Department
IMFsoft, s.r.o.
I had swapped the +5 ( red ) and G ( black ) wires.
And manual drawing was a principal drawing.
Back to wrenching.
Hope this can be of any help for you.
