Öl-Bibel
BMW-Guzzi
17. Juli 2010
kurz vor HH
Moin zusammen,
hier mal wieder ein Zufallsfund aus den Weiten des www
für Freunde des allseits beliebten Themas "ÖL".
Es geht allgemein um Öl, also nicht speziell um Motorradöle.
Zitat:
This FREE Motor Oil Bible Download Discusses:
  • Viscosity- Monogrades vs Multigrades, how to understand the numbers, problems with multi-viscosity motor oils, the solution – pretty much everything you could want to know about motor oil viscosity.
  • Is Synthetic Right for YOU- Older vehicles, low mileage drivers, leasing, extended drains
  • Other Synthetic Oil FAQs- Switching from petroleum to synthetic, compatibility, when to switch, when not to, how to switch, oil pressure
  • General Motor Oil FAQs- How to choose, motor oil types, basestocks, which viscosity, comparing the specs
  • Why to Change Oil – Or Not- Discussing the issues surrounding short vs long drain intervals, companies offering long drain oils, why some are still calling for 3-5K changes, warranty issues.
  • Change Your Oil the RIGHT WAY! – A chapter solely devoted to making your oil changes as simple as possible, either through modifying your procedure or by acquiring a few specific “labor saving devices (or both).
Zitat Ende
Quelle: http://themotoroilevaluator.com/members-blog/the-motor-oil-bible-free/
Download: http://themotoroilevaluator.com/free-preview-version.pdf
Christian
DBX: ÖL
