Tacho und Hinterreifen wechseln
BenedictBrown
Einsteiger
06. Aug. 2021
5 Best Review Guides On Simple Garden Care
How to take care of the garden effectively is a question many people ask when they intend to grow clean vegetables at home. Growing vegetables is difficult, but growing them correctly to be productive is a bit more complicated.
In particular, each vegetable has a way of being taken care of, such as the amount of water for irrigation, the time to fertilize, etc. Please refer to the 5 best reviews guide at TheKingLive below to take care of the vegetable garden!
Water the plants regularly
Water is always an essential material in the growth and development of plants. However, taking care of vegetables is not just about water being effective and green vegetables are good.
Depending on how well the soil can hold the soil, whether the temperature and humidity conditions in the air are high or low to irrigate sufficient water for plants.
In the process of watering, you need to water evenly and distribute it in all plants, avoiding over-watering that will cause them to become waterlogged and die.
Fertilize plants
Fertilize vegetables to provide more necessary nutrients, create conditions for plants to grow and develop well. For each type of plant, there will be an appropriate type of fertilizer and amount of fertilizer.
However, if you don't know what fertilizer is suitable for your plants, spend some time on amazon reviews to read and learn more.
Some notes to make fertilizer effective:
- Apply the necessary amount of fertilizer, neither too much nor too little.
- Fertilize according to the growing period of the plant.
- Fertilize following the correct method. Currently, there are main fertilization methods, including fertilizing the soil, applying fertilizer to vegetables, applying fertilizer through leaves, and applying fertilizer through the roots.
- The balance between the elements in the fertilizer to fertilize
Control plant growth
In taking care of the vegetable garden, you can use different measures to regulate the growth and development of plants. Here are some steps you can refer to:
Cut tops, pruning branches, breaking tassels
This is the method used for climbing plants. In tree development, when using this method, the tree will produce more branches and more tendrils.
When the tree branches, it means that it will quickly bear fruit. For plants that are slow or not branching, it means that they lack nutrients.
Pruning flowers and fruit
In planting and taking care of plants, it is easy to encounter a situation where the tree does not have enough nutrients, causing flowers and fruits to fall a lot.
Therefore, you need to regularly prune flowers and fruits to help plants achieve higher yields.
Remove underdeveloped plants
After sowing, we will notice that the plants that grow healthy, free from pests will keep. Trees that are regularly eaten by pests can be trimmed down or entirely removed to avoid affecting other trees.
In addition, during planting, you should consider the appropriate spacing between plants. The reason is that when the density is too thick, the soil will not have enough nutrients to evenly supply the plants, causing the plants to be stunted and slow to grow.
Prevention of natural phenomena
According to Joseph French - an expert at TheKingLive, it will be difficult for you to avoid situations such as cold and heat of the climate and weather during the planting process. These natural factors also affect the growth of the plant, more or less.
Therefore, you should grow vegetables indoors, with glass and a roof to ensure safe plants. In addition, it is advisable for some areas to choose an organic fertilizer to fertilize the root to prevent rust and water dew.
Plow the soil and remove the weeds
When growing vegetables, you should regularly check the soil to be loose, porous, and hold water. Tilling the soil will create conditions for aerobic microorganisms in the ground to accelerate the process of activity, helping to decompose faster.
You should choose a dry day to dig the soil, avoid breaking the tree and damage the roots to affect the crop yield.
Pest control for plants
Vegetables are always a crop that is damaged by many pests. Therefore, you should regularly check and take timely measures to prevent it.
Currently, there are many drugs on the market to help prevent pests and diseases, such as chemical pesticides, biological pesticides, herbal insecticides, etc....
Thus, today's article has sent you the best reviews ever on planting and taking care of vegetable gardens. Hopefully, the above sharing will help you take care of your vegetable garden well!
Address: 4150 Portillo Rd #29, Spring Hill, FL 34608, United States
ich fnde nur leider keine Formel in der DB, um aus den Angaben die neue Wegdrehzahl zu berechnen?
Danke!!
Hallo Benedict,
das ist natürlich ärgerlich, wenn das nicht drin steht. Was soll denn für ein Reifen montiert werden?
Hallo Zusammen,
aufgrund Tachoänderung und anderem Hinterreifen, möchte ich die neue Wegdrehzahl berechnen.
Umfang Hinterrad ist 2098 mm
Tachoübersetzung Monolever gemäß DB 6/13
Hinterachse ist eine 32/10
Danke!!
In der angehängte Darstellung aus der Datenbank steht alles Wesentliche, die Formel musst Du Dir selber daraus ableiten.
