BMW MONOLEVER FINAL DRIVE (thru axle - ribbed case - 10/32 or 11/34)
Hi everyone, nice to meet you.
I am not very experienced with BMW airhead 2V and I signed up for useful information. I apologize for not speaking German and for my rusty English.
I would like to know if there are monolever Bmw motorcycles equipped with 10/32 or 11/34 FINAL DRIVE WITH THRU AXLE AND RIBBED CASE (like in photo B).
Anhang 264234
I don't think so. I think they exist only with smooth case (like in photo A)
Anhang 264235
If I'm wrong may U tell me the model and year of the BMW motorcycle ?
THANK U
AW: BMW MONOLEVER FINAL DRIVE (thru axle - ribbed case - 10/32 or 11/34)
Zitat:
Zitat von
HOOK74
It's just the other way. The "smooth" housing was used with the /5 to /7 series (dual arm lever). The Monolever series always came with the ribbed housing.
Regarding the available gear ratios: You will find plenty of information in the "rear drive chapter" of our BMW data base. The most should be understandable even to a non-german-speaking reader.
These might be most interesting:
Teil 7 Hinterradantrieb Monolever-Modelle Baureihe 247e Baujahr 1981-1992
Teil 8 Hinterradantrieb Monolever-Modelle Baureihe 247 85 Baujahr 1985-1995
Give it a try!
Kind regards
Stefan
Zitat:
Zitat von
HOOK74
Anhang 264234
Anhang 264235
THANK U
Hello,
the translations are available. 32/10 and 34/11 more than rare, 37/11 with the R80
Greeting
Zitat:
Zitat von
Euklid55
Hello,
Greeting
Thank U to all for these infos.
To Walter,
Do U mean I should have used the translator rather than my rusty English?
Meinst du, ich hätte eher den Übersetzer als mein rostiges Englisch benutzen sollen?
if it works I'll do..
it works?
Zitat:
Zitat von
HOOK74
To Walter,
it works?
I'm not Walter, but
- the translator worked, but from my point of view you'd better stick to English since all these automatic translators create crappy wordings every once in a while.
- the correct term in Walter's post would have been "transmission ratio". ;)
Zitat:
Zitat von
hansen_reloaded
I'm not Walter, but
ahahhahah :D
it's ok
thank u
BTW: For automatic translation I would give deepl a try. Works quite well!
34/11 on Monolever didn´t ever exist.
33/11 is it (on RT and RS) :oberl:
Zitat:
Zitat von
boxerhans
Whow Flatengine-John,
you can transport this meanful Information in that god damned bad english language!?
Like neulich. I'm very beeindruckt about your flexibility!
So please tell us: what's the meaning of :oberl: in german?
sincerely your's
Werner ;)
Warum brauchst Du diese Informationen?
Why do you need this information? (Translated by DeepL)
