32/10 - 33/11 FINAL DRIVE -Hinteradantrieb
Hi I'm looking for a 32/10 or 33/11 final drive, thru axle, drum brake and ribber case ...completely overhauled & reconditioned.
Like the one in the added photo.
I had found and bought a 32/10 but unfortunately it is completely malfunctioning.
I have urgency and so I try to ask you too. maybe you have some useful information.
Thanks
Liste der Anhänge anzeigen (Anzahl: 10)
AW: 32/10 - 33/11 FINAL DRIVE -Hinteradantrieb
Hello, I send you a private message.
...with 1070cc big bore using my BMW 60% road (mountain road, uphill & downhill asphalt roads) 40% off road to you think is better 32/10 or 33/11?
i haven't driven 1070cc yet...
Hello,
in comparision to:
32 : 10 = 3,2, transmission shorter
33 : 11 = 3,0, transmission longer
60% road, uphill
40% off road
I prefer the shorter transmission.
caddytischer, Claus
Yes, it´s a mountainracer, be quick.:D:D:D downhill:schock::schock::schock::D
...the problem is that 32/10 with ribbed casing , drum brake and thru axle it's very difficult to find.
So 33-11 could be a temporary option even if LONGER
Zitat:
Zitat von
HOOK74
So 33-11 could be a temporary option even if shorter
First of all, it‘s 10:32=0.3125 and 11:33=0.333
The 2nd one is longer.
Mountainious roads and offroad asks for short transmission, even with punch at low rpm.
WHy Don‘t you get yours overhauled , which might not take too long and you have an approved one instead of another can of worms from ebay?
Cheers, Frank
Zitat:
Zitat von
Tam92
Cheers, Frank
Yes, it's longer it was a mistake
my mechanic is changing workshop and he needs the final drive as soon as possible. I can consider to overhaul mine but he prefer to find a completely overhauled final drive with warranty.
