Ergebnis 1 bis 7 von 7
17.02.2021, 21:36 #1
- 15.09.2020
DELL'ORTO PHM40 CARB-VERGASER
Hello
I just mounted Dell'ORTO PHM40 carburetors on my R100GS.
Any of you have any useful reference for the setting?
Thank U
Ich habe gerade Dell'ORTO PHM40 Vergaser an meinem R100GS montiert.
Hat jemand von euch eine nützliche Referenz für die Einstellung?
Danke
02.05.2021, 19:16 #2
- 15.09.2020
AW: DELL'ORTO PHM40 CARB-VERGASER
...hallo, does anyone have any infos?
03.05.2021, 06:21 #3
für 40 Dello ND260, HD165, LL 57, Nadel 1. v.oben. Nadel K4 oder K13
Personally, I don't think much of the carburettors.
WalterGeändert von Euklid55 (03.05.2021 um 06:23 Uhr)
03.05.2021, 07:40 #4
it would be good to know if you have done any other modifications on your bike (exhaust, air intake, engine tuning,...) ?
the setting walther posted is a setup which will work quite sure. depending on your own requirements you can invest days or weeks to improve further.
there a lot of threads here discussing this, including lambda logging, dynos and tables with the details of the needle forms.gruß christian
03.05.2021, 22:02 #5
- 15.09.2020
Thank you both.
I was interested in having a rough setting to compare it to the R4923 and 4924 setting of my Moto Guzzi PHM40's.
My BMW R100GS is equipped with K&N air filter (outside the air box), 1070BBK from siebenrock and enduro sport camshaft.
I still have to run, test and try the bike. .Geändert von HOOK74 (03.05.2021 um 22:28 Uhr)
03.05.2021, 22:25 #6
- 15.09.2020
WHAT FORGOTTEN! I had also seen a video not long ago ...
age begins to make itself felt
04.05.2021, 00:04 #7
- 15.09.2020
I apologize for writing a post without first looking for information on the forum.
Felgenwahl 1. Serie /5
25.04.2024, 21:40 in Mechanik
