Ergebnis 1 bis 10 von 12
Thema: Notch on the rim
Hybrid-Darstellung
30.06.2021, 16:09 #1
AW: Notch on the rim
E. Snowden
Safety stuff, solid german engineering around 1930 by Kronprinz, Solingen.
Stops the tire rim to slip in the deep bed in case of pressure failure, dismantling from the wheel consequently.
Tires are a bit tricky to assemble, working contrary compared to standard wheels.
Cheers, Frank
E. Snowden
Bremslichtschalter prüfen?
22.05.2024, 23:37 in Elektrik
