Ergebnis 1 bis 10 von 19
15.09.2020, 12:52 #1
- 15.09.2020
BMW MONOLEVER FINAL DRIVE (thru axle - ribbed case - 10/32 or 11/34)
Hi everyone, nice to meet you.
I am not very experienced with BMW airhead 2V and I signed up for useful information. I apologize for not speaking German and for my rusty English.
I would like to know if there are monolever Bmw motorcycles equipped with 10/32 or 11/34 FINAL DRIVE WITH THRU AXLE AND RIBBED CASE (like in photo B).
I don't think so. I think they exist only with smooth case (like in photo A)
If I'm wrong may U tell me the model and year of the BMW motorcycle ?
THANK UGeändert von HOOK74 (15.09.2020 um 12:54 Uhr)
15.09.2020, 13:07 #2
AW: BMW MONOLEVER FINAL DRIVE (thru axle - ribbed case - 10/32 or 11/34)
It's just the other way. The "smooth" housing was used with the /5 to /7 series (dual arm lever). The Monolever series always came with the ribbed housing.
Regarding the available gear ratios: You will find plenty of information in the "rear drive chapter" of our BMW data base. The most should be understandable even to a non-german-speaking reader.
These might be most interesting:
Teil 7 Hinterradantrieb Monolever-Modelle Baureihe 247e Baujahr 1981-1992
Teil 8 Hinterradantrieb Monolever-Modelle Baureihe 247 85 Baujahr 1985-1995
Give it a try!
Kind regards
StefanViele Grüße
Stefan
Die blaue Q:
R75/6 (1976) mit
Doppelscheibenbremse
15.09.2020, 13:13 #3
15.09.2020, 15:35 #4
- 15.09.2020
Geändert von HOOK74 (15.09.2020 um 15:37 Uhr)
15.09.2020, 15:56 #5
- 24.01.2017
- Mönkeberg
15.09.2020, 16:01 #6
- 15.09.2020
15.09.2020, 16:23 #7
BTW: For automatic translation I would give deepl a try. Works quite well!
Stefan
Die blaue Q:
R75/6 (1976) mit
15.09.2020, 16:44 #8
34/11 on Monolever didn´t ever exist.
33/11 is it (on RT and RS)Beste Grüße
15.09.2020, 17:04 #9
- 06.04.2009
- Wuppertal-Ronsdorf
15.09.2020, 17:36 #10
- 30.10.2007
Warum brauchst Du diese Informationen?
Why do you need this information? (Translated by DeepL)
Warum löst sich die zentrale...
18.04.2024, 20:27 in Mechanik
