Ergebnis 1 bis 10 von 17
12.01.2021, 21:14 #1
- 15.09.2020
32/10 - 33/11 FINAL DRIVE -Hinteradantrieb
Hi I'm looking for a 32/10 or 33/11 final drive, thru axle, drum brake and ribber case ...completely overhauled & reconditioned.
Like the one in the added photo.
I had found and bought a 32/10 but unfortunately it is completely malfunctioning.
I have urgency and so I try to ask you too. maybe you have some useful information.
Thanks
12.01.2021, 21:48 #2
- 27.02.2007
- 53859 Niederkassel
AW: 32/10 - 33/11 FINAL DRIVE -Hinteradantrieb
Close to perfect.
12.01.2021, 21:54 #3
- 15.09.2020
Hello, I send you a private message.
12.01.2021, 21:57 #4
- 15.09.2020
...with 1070cc big bore using my BMW 60% road (mountain road, uphill & downhill asphalt roads) 40% off road to you think is better 32/10 or 33/11?
i haven't driven 1070cc yet...
13.01.2021, 14:08 #5
Hello,
in comparision to:
32 : 10 = 3,2, transmission shorter
33 : 11 = 3,0, transmission longer
60% road, uphill
40% off road
I prefer the shorter transmission.
caddytischer, Clauscaddytischer, Claus
BMW R50, mit R80 Gleitlagermotor, ganze 50 PS, /5 Gabel
14.01.2021, 18:23 #6
- 15.09.2020
...I agree with you
14.01.2021, 19:23 #7
Yes, it´s a mountainracer, be quick. downhill
caddytischer, Claus
14.01.2021, 20:02 #8
- 15.09.2020
...the problem is that 32/10 with ribbed casing , drum brake and thru axle it's very difficult to find.
So 33-11 could be a temporary option even if LONGERGeändert von HOOK74 (14.01.2021 um 21:30 Uhr)
14.01.2021, 20:31 #9
First of all, it‘s 10:32=0.3125 and 11:33=0.333
The 2nd one is longer.
Mountainious roads and offroad asks for short transmission, even with punch at low rpm.
WHy Don‘t you get yours overhauled , which might not take too long and you have an approved one instead of another can of worms from ebay?
Cheers, FrankGeändert von Tam92 (14.01.2021 um 20:32 Uhr)
E. Snowden
14.01.2021, 21:34 #10
- 15.09.2020
Felgenwahl 1. Serie /5
25.04.2024, 21:40 in Mechanik
