Ergebnis 1 bis 1 von 1
21.04.2012, 10:28 #1
Understanding And Maintaining The BMW /2 Electrical System
This manual was written to help owners of /2 BMW motorcycles to service their bikes and keep them in running condition. When these motorcycles were made, they had very different electrical requirements to motorcycles today, and used equipment which today’s owner may not fully understand. Doug and Kees hope that this manual is useful to owners of these motorcycles and that it will help owners keep their bikes where they belong – on the road.
- Introduction
Electrical System Overview - Understanding the Ignition System
The Magneto ~ The Points ~ The Capacitor (Condenser) ~ The Coil - Adjusting The Spark ~ Checking the Magneto Position ~ Repositioning the Magneto Rotor ~ Setting the Timing
- Understanding the Charging System
Wiring Guide ~ Maintaining the Generator ~ Maintaining the Regulator - Testing The Charging System
Test 1: No Load Voltage ~ Test 2: Cut-In Voltage ~ Test 3: Load Voltage ~ Test 4: Reverse Current ~ Look After Your Battery ~ What To Do - Ignition Problems
Weak Ignition Spring ~ Advance/Retard - Tutorial: How The Ignition System REALLY Works
What the Magneto is doing ~ Charts - Specifications
- Replacement Parts
- Wiring Diagram Colour Cross-Reference
Main Wiring ~ Turn Indicators - Wiring Diagrams
Connections ~ BMW Wiring Scheme #1 ~ BMW Wiring Scheme #2
Quellen:
http://www.dennisontwitter.com/pdf-b...g-maintaining/
http://www.snafu.org/restore/uandm_bmw_v1.pdf
DBX: ELEKTRIK, /2, BAUGRUPPE-12, BAUGRUPPE-61, BAUGRUPPE-63Viel Spaß
Christian
- Introduction
Tausch KWG Rückschlagventil
16.06.2024, 02:31 in Mechanik
