Ok
Tried in german will try now in english
A fellow biker has a rebuild 100/7 with a tuned 1000cc engine.
Tuned as in sport camshaft, carbs, exhaust with silencer and so on.
The responce of the engine are much faster than standard engine meaning that the rpm-meter will not follow the engine rpm at 1'st and 2'nd gear, gears above that are no problem.
Secondly the meter are limited to 7000rpm and this engine runs up to 7500-8000rpm dependent of the above tuning and a compleate outbalance of the engine.
Guess there could be a capacitor on the meter PCB and some kind of electric limiter.
BTW. a mechanical prm meter follows the engine well and no upper rpm limit. Has it on my R100RS/MKM engine. But it's a bit of work to convert the engine to mechanical rpm meter.
