Ergebnis 1 bis 8 von 8
14.01.2022, 16:39 #1
- 15.09.2020
Strebe - Paraleverstrebe 365mm
Hallo, hat jemand eine R1100GS Schwinge auf einem R80/R100 2V Rahmen mit Strebe - Paraleverstrebe (365mm für BMW R 850 - 1150 - 1100 GS) verstellbar montiert, so dass man das Heck des Motorrads anheben/absenken kann?
Wie viele mm Einstellung haben Sie gewählt?
Danke
Hi, has anyone mounted a R1100GS swingarm on a R80/R100 2V frame with strut - paralell strut (365mm for BMW R 850 - 1150 -1100 GS) adjustable so you can raise/lower the rear of the bike?
How many mm adjustment you have chosen?
ThanksGeändert von HOOK74 (16.01.2022 um 10:00 Uhr)
14.01.2022, 18:46 #2
AW: Strebe - Paraleverstrebe 365mm
I use the MV-Verholen adjustable strut. But with a 1150 swingarm. This strut was for a R1100S and too long. So, I have had cut them. But you need for my point of view only the original R1100 GS strut length, or not!?
16.01.2022, 10:02 #3
- 15.09.2020
Hi, thanks for your reply.
I think I didn't explain myself well and made a mistake...also in translation.
Anyway the 365mm torque arm is originally mounted on R850GS-R1100GS- R1150GS-R1100S
The 385mm one on R850R-R1100R-R1150R rockster-R850RT-R1100RT-R1150RS-R1150RT.
I am adapting an R1100GS swingarm on R100GS frame. I haven't decided yet whether to tilt the engine, but since I have to make some measurements I wanted to build an adjustable torque arm so that I can (in relation to the Ujoint working angle) check if and how much I can raise the rear of the bike (having longer forks). Maybe something already exists on the market, maybe not. If I have to build it I was wondering how many mm of adjustment would be right for all my measurements.
Translated with www.DeepL.com/Translator (free version)
16.01.2022, 17:17 #4
- 08.11.2011
- 47533 Kleve/ Niederrhein
I modified the original one from the R100GS....
16.01.2022, 18:51 #5
- 15.09.2020
16.01.2022, 19:57 #6
For testing you could use a timber slat, with two holes with a distance of 365mm and 385mm. Or the second way cut the original one and install a normal threaded bar. But only for test purpose
16.01.2022, 20:09 #7
- 15.09.2020
16.01.2022, 22:13 #8
This is the best way!
Woran erkennt man die alten...
26.05.2024, 10:53 in Mechanik
