32/10 - 33/11 FINAL DRIVE -Hinteradantrieb
HOOK74
15. Sep. 2020
Hi I'm looking for a 32/10 or 33/11 final drive, thru axle, drum brake and ribber case ...completely overhauled & reconditioned.
Like the one in the added photo.
I had found and bought a 32/10 but unfortunately it is completely malfunctioning.
I have urgency and so I try to ask you too. maybe you have some useful information.
Thanks
Close to perfect.
...with 1070cc big bore using my BMW 60% road (mountain road, uphill & downhill asphalt roads) 40% off road to you think is better 32/10 or 33/11?
i haven't driven 1070cc yet...
...the problem is that 32/10 with ribbed casing , drum brake and thru axle it's very difficult to find.
So 33-11 could be a temporary option even if LONGER
So 33-11 could be a temporary option even if shorter
First of all, it‘s 10:32=0.3125 and 11:33=0.333
The 2nd one is longer.
Mountainious roads and offroad asks for short transmission, even with punch at low rpm.
WHy Don‘t you get yours overhauled , which might not take too long and you have an approved one instead of another can of worms from ebay?
Cheers, Frank
Cheers, Frank
Yes, it's longer it was a mistake
my mechanic is changing workshop and he needs the final drive as soon as possible. I can consider to overhaul mine but he prefer to find a completely overhauled final drive with warranty.
Rare as hen‘s teeth I would assume.
Guess you can get it back completely overhauled within 2 weeks more or less.
Mine did take a week.
Up to you, cheers, Frank
it is rare to find 10/32 ratio. 11/33 easier, like 11/37 (too short)
I think the BMW replacement crown-pinion 32-10 is no longer available
No idea, you might just ask the experts.
Why‘s 11/37 ratio too short?
Might be perfect uphill and offroad unless you want to go for long distances on the motorway.
I had a test drive on a G/S of a friend with this ratio and BBK.
Amazing ride with lots of torque in high gear even in narrow slopes.
Would be my choice, cheers Frank
37/11 with 78/80 HP from a BBK
not without Tireholder
I only tried 11/34 on my standard r100gs.
it was a good one ratio for my use.
now my Bmw is completely different as transmission and engine.
the engine is 1070cc with lightened crankshaft and camshaft for high torque at low-medium rpm. My mechanic says that 37/11 is too short and also 32/10 but less ( the limit)
As long as you can‘t drive up a tree, it’s not too short.:D
As usual, it‘s up to you.
For me 11/37 is ok for road and light offroad.
But I‘m no rallye guy.
Cheers, Frank
