Lithium Ionen Batterie für R100R
Und fuer alle die was zum Spielen brauchen😇😎
70ah, 7,7kg, 500a burst
Das ist ja nur begrenzt durch das bms
Die batt selber kann mehr.
Es sind calb zellen verbaut. Sin so die besten zellen.
Fuer mi zum spielen oifach super
Ich hab eine LifPo in der Buell. Wenn ich die über 'n Winter abklemme, brauch' ich da niGS dran zutun. Die springt zuverlässig im Früjahr an. . .
Stephan
Hello
Danish guy here. My german isn't great, so I hope you will bear with me: happy:
I am going for LifePo4 in my R100 / 7 from 1978 for a café build.
I have the same JMT battery as several mentions in this thread (and appropriate charger):
And I changed out the Bosch starter with a valeo equivalent:
And I am running a new voltage regulator with constant 14,3:
I am planning on running LED blinkers (with new LED relay) and rearlight:
And I am keeping the old headlight with H4 Bulb:
I am not changing the charging system or points / condenser ignition.
What do you think of this setup? :You're welcome:
Again, sorry I couldn't do it in german... long time lurker here. It's the best forum for 2-ventiler boxers!
Best
