tibbet
Hi
Renovating my -76R100RS / MKM4V I'm on the breaks now.
As the breaks has limited effect, i prefere to have them in tip top state.
Riding in the alps can be very interesting as autobahnfahrt.
Swapped the rubber tubes to flexible tubes with steel surface.
On to renovatiing the calipers - pistons and sealings.
A Q. on this the adjustment seems to stuck, any tips on make them move smoother.
Secondly any idea to swap the main cylinder under the tank to get more pressure on the break pads.
About the rear break, a natural way would be to swap the drumbreaks to diskbreaks but then I would probably have to install AL rims instead of the original wire rims in silver with blue stripes.
Maybee better to install newer forks with f.ex. 4 pistons calipers. Well that could be the next step, meanwhile I have to continue to plan ahead my breaking.
PS the 4VMKM engine delivers appr. 90 PS with Mikuni carbs. modified silencers and openup airintake and filters. Making the bike run a bit above 200kmh and it doesn't take to long for it to reach 200.
Reinforced the framwork to make it more stable feels more comfortable crusing in 170 trough germany or on our local but not always so flat tarmac roads. May I say that wobbling are not an issue.
