Seite 1 von 2 12 LetzteLetzte
Ergebnis 1 bis 10 von 19
  1. #1
    Registriert seit
    15.09.2020
    BMW MONOLEVER FINAL DRIVE (thru axle - ribbed case - 10/32 or 11/34)
    Hi everyone, nice to meet you.
    I am not very experienced with BMW airhead 2V and I signed up for useful information. I apologize for not speaking German and for my rusty English.
    I would like to know if there are monolever Bmw motorcycles equipped with 10/32 or 11/34 FINAL DRIVE WITH THRU AXLE AND RIBBED CASE (like in photo B).
Hits:	34
Größe:	28,9 KB
    I don't think so. I think they exist only with smooth case (like in photo A)
Hits:	27
Größe:	203,1 KB
    If I'm wrong may U tell me the model and year of the BMW motorcycle ?
    THANK U
    Geändert von HOOK74 (15.09.2020 um 12:54 Uhr)
  2. #2
    Admin Avatar von dl6dx
    Registriert seit
    19.04.2009
    Telgte
    AW: BMW MONOLEVER FINAL DRIVE (thru axle - ribbed case - 10/32 or 11/34)
    It's just the other way. The "smooth" housing was used with the /5 to /7 series (dual arm lever). The Monolever series always came with the ribbed housing.
    Regarding the available gear ratios: You will find plenty of information in the "rear drive chapter" of our BMW data base. The most should be understandable even to a non-german-speaking reader.
    These might be most interesting:
    Teil 7 Hinterradantrieb Monolever-Modelle Baureihe 247e Baujahr 1981-1992
    Teil 8 Hinterradantrieb Monolever-Modelle Baureihe 247 85 Baujahr 1985-1995
    Give it a try!
    Kind regards
    Stefan
    Stefan
    Die blaue Q:
    R75/6 (1976) mit
    Doppelscheibenbremse
    und S-Cockpit
    Streckensperrungen betreffen uns alle!
  3. #3
    Registriert seit
    27.10.2007
    Frankfurt und Neustadt a.d. W
Hits:	34
Größe:	28,9 KB
Hits:	27
Größe:	203,1 KB
    THANK U
    Hello,
    the translations are available. 32/10 and 34/11 more than rare, 37/11 with the R80
    Greeting
  4. #4
    Registriert seit
    15.09.2020
    Zitat Zitat von Euklid55 Beitrag anzeigen
    Hello,
    Greeting
    Thank U to all for these infos.
    To Walter,
    Do U mean I should have used the translator rather than my rusty English?
    Meinst du, ich hätte eher den Übersetzer als mein rostiges Englisch benutzen sollen?
    if it works I'll do..
    it works?
    Geändert von HOOK74 (15.09.2020 um 15:37 Uhr)
  5. #5
    Registriert seit
    24.01.2017
    Mönkeberg
    To Walter,
    it works?
    I'm not Walter, but
    - the translator worked, but from my point of view you'd better stick to English since all these automatic translators create crappy wordings every once in a while.
    - the correct term in Walter's post would have been "transmission ratio".
  6. #6
    Registriert seit
    15.09.2020
    Zitat Zitat von hansen_reloaded Beitrag anzeigen
    I'm not Walter, but
    ahahhahah
    it's ok
    thank u
  7. #7
    Registriert seit
    19.04.2009
    Telgte
    BTW: For automatic translation I would give deepl a try. Works quite well!
    Stefan
    Die blaue Q:
    R75/6 (1976) mit
    und S-Cockpit
  8. #8
    Leben und leben lassen Avatar von boxerhans
    Registriert seit
    15.06.2009
    Kreis Altötting, Oberbayern
    34/11 on Monolever didn´t ever exist.
    33/11 is it (on RT and RS)
    Beste Grüße
  9. #9
    Registriert seit
    06.04.2009
    Wuppertal-Ronsdorf
    Whow Flatengine-John,
    you can transport this meanful Information in that god damned bad english language!?
    Like neulich. I'm very beeindruckt about your flexibility!
    So please tell us: what's the meaning of in german?
    sincerely your's
    Werner
  10. #10
    Registriert seit
    30.10.2007
    Warum brauchst Du diese Informationen?
    Why do you need this information? (Translated by DeepL)
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
OK, verstanden
